BEST adjustable Trackbars?!
I have an OME HD and was wondering who makes the best adjustable trackbar for 2-3.5" lift I say 2-3.5 because I am not sure how much lift I will get after the bumpers ... I have heard problems on this forum with Teraflex & Full Traction...
any suggestions...
any suggestions...
I have not heard of any problem unless you are referring to a SEPERATE problem with the stress on the OEM(Mopar) brackets.
I will be putting on my Full Traction front/rear bars as soon as they get here and could post if these are difficult to install or if I see any problems. Here's to hoping for centered axels and no more ESP problems!
[Thanx to David @ Northridge for setting me up with the FT Trackbars as well]
I recently installed the FT adjustable bars front and rear. Quality components and easy install makes this a great upgrade for those requiring axle re-centering. If you follow WOL's writeup, you will have no issues. I Couldn't be happier with the purchase.
Damn good idea! Did you drill and tap the upper mount tube so the zerk feeds grease in between the tube and the bushing?
