Best cleaning solvent before applying Raptor Bedliner?
Old Jul 23, 2014 | 03:05 AM
Hatingonyou's Avatar
Default Best cleaning solvent before applying Raptor Bedliner?
I am about to Raptor Liner my Wrangler soon and have done extensive reading about it. Everyone says it is all in the prep, but don't state what cleaner they are using. Opinions?
Old Jul 23, 2014 | 03:10 AM
Mountain Man Tim's Avatar
depends on what you are lineing, if its any of the plastic, just dawn to degrease and rubbing alc after the rinse to take off any touch spots. if current paint, something harsher to take off wax and etch into the paint, usually acidic or you can sand by hand, you want a rough surface to bond too, generally the instructions of how to bedline a pick up trucks box, tell you what you need to do for the prep, just apply to all the metal surfaces you want to bedline.
Old Jul 23, 2014 | 06:02 AM
sea bass's Avatar
I used denatured alcohol after sanding and roughing everything up.
Old Jul 23, 2014 | 06:21 AM
Vladimer's Avatar
I used MEK (Methyl ethyl ketone) when I did my Monstaliner as it was the recommended product to use in their instructions. I picked it up at Canadian Tire.
