best discos to use
hey there, here it is there are so many discos out there but which ones have stoud up to daily driving abuse and easily disconnected for trail fun. single disco, double disco. please help.
I ordered a set of RB's and they sent me a set for the TJ's. The JK's have that attached bolt on the top. Called them, they said they were working on it...maybe October.
Went with a set of JKS Quicker Disconnectors. You don't have to be leveled to connect or disconnect. Easy on and off. They're holding up very well so far. Just make sure you order the right set depending on your lift size.
I have the RE Gen 2's. They are good/ok. But after looking at the JKS im jealous. I have to zip tie the discos to back to the sway bar or somewhere else. The JKSs come right off top and bottom I believe.
I've got the Teraflex discos and I'm very happy with them. Just pull the pins, rotate the swaybar up and and connect it to the other pin that's provided with the discos. No zip tying or bungi cords. Takes 1-2 minutes to disconnect and connect.
Here's a link to another thread with pics
https://www.jk-forum.com/forums/show...teraflex+disco
