Best gear ratio for 33" tires
Old Jul 4, 2010 | 05:55 PM
fawkes's Avatar
Default Best gear ratio for 33" tires
I have a Wrangler X with the automatic (rather unfortunate side effect of getting a spectacular deal on a used Jeep, the only thing it didn't have that I wanted was a manual). That being said, I just put the TF leveling kit, and some 33 inch tires on there. It is not absolutely terrible to drive, but the 3.73's are just barely adequate. I wonder if anyone has bothered to re-gear for 33s on an X, and what gear ratio they used. I would also like to have a happy medium between the 33s and possible 35s in the future, but that is FAR into the future. Thanks for your help!
Old Jul 4, 2010 | 06:10 PM
opdsgt's Avatar
This is my thread. There are many like it, but this one is mine.
https://www.jk-forum.com/forums/showthread.php?98283
Sorry, watching FMJ tonight, couldn't resist.
Old Jul 4, 2010 | 07:36 PM
nthinuf's Avatar
Do you plan on moving up to 35's any time in the semi near future?
If you open the DriveTrain FAQ's (nailed right at the top of this modified section!!!) you'll find a great RPM chart. Plug in some numbers and see what you come up with. And be sure to use the 'actual' tire height, not the mfg's listed height!
Just an opinion, but I would gear for 35's and not 33's...
Old Jul 4, 2010 | 08:01 PM
fawkes's Avatar
35s are only a small possibility in the distant future... more likely I will stick with 33s while this is a dd, and then go to some full size axles and much larger tires, when I can afford a second vehicle
Old Jul 4, 2010 | 08:09 PM
tslewisz's Avatar
Originally Posted by planman
Because you have an automatic, you should go the lowest possible--which is 5.13s for an X with a front Dana 30.
I agree. And I have them with a 6-speed and 32's.
Old Jul 4, 2010 | 09:05 PM
Cedo Nulli's Avatar
Hard to decide either way....I"m going 5.13s, because mine is a DD, but with the roof rack, winch, bumpers, wheels/tires, etc it's bogged it down a bit with my 4.10s. I'd like to go 35s in the future also so...
Do it right the first time and go 5.13s. If you ever go 35s, or start bolting a bunch of stuff on the jeep you won't need to regear again.
Old Jul 4, 2010 | 11:24 PM
fawkes's Avatar
Thanks for the info guys, I think I've narrowed my decision down to either 4.88 or 5.13. Now to find a good shop in CO to do the work, for a reasonable price!
Old Jul 5, 2010 | 03:36 AM
RedRock GatorRaider's Avatar
Yeah right, I've heard that before. I give you 6 months till you're sporting 35s.
