Best locker for front dana 30?
I just recently shredded the teeth on my ring and pinion on front dana 30 axle with 5.13 gears. I plan on getting new gears and while it is torn apart I would also like to install a locker, diff cover and anything to help strengthen the ring and pinion. I was curious as to what would be the best locker for the front, I currently just have limited slip in the stock rear diff. Any advice is greatly appreciated, thanks.
The only way to prevent sheering the teeth again would be to go numerically down on the gears or don't drive so hard. Putting a locker in the front is definitely not going to help things. It sounds to me like it is time to upgrade the axle, i'm thinking a 44 or 60 may be in order.
Thanks for the advice guys. I am only running 35" tires so I think an axle swap might be a little unnecessary and too expensive for me. Also I already have 5.13's in the rear diff so I am trying to keep the same gears to avoid tearing in to the rear diff again. Sounds like I just need to drive a little easier and use less pedal while in 4 low. I know other people are running this set up with no problems so it must just be my driving (gonna have to work on that). Leaning towards the TrueTrac right now but all great advice.
The one thing to really try and avoid is bouncing your front end under power. The releasing of traction lets your tires spin and when they grab again it puts a lot of strain on the gears, ujoints and shafts. It's is just a matter of time before something gives. Think light throttle. It's called crawling for a reason.
