Best power for the $$$
Towing two jet skis on a double trailer I was again reminded how pathetically under powered my Sahara 4dr 6sp JK is. yes I have 33+'s tires etc but come on, this thing was struggling hard on the highway. Anyway I love my jeep but need more power. What have people see with proven results? Under 1k total; for example CAI (which one?) Exhaust (which one?) software (or is this a waste?) or a combo of all plus something else? any and all input welcomed...... any word on a supercharger coming out anytime soon for the JK?
Oh one of my jet skis has more HP then my jeep if you believe that , stock with NO mods ...... sea do RXT SC 215hp from the factory..... bet my ski would pull my jeep better then the jeep pulls the ski's
gears are going to make the biggest difference, if you don't already have the 4.10's. cold air intake with a throttle body spacer would make the next biggest improvement. after that would be a new cat-back system - borla or magnaflow are good.
if you enhance your intake and exhaust, then use a jet stage 2 chip, that would make a good improvement.
if you did the re-gear yourself (i have no idea what labor would be to have it done - probably in the ballpark of $500-700) you could add an airaid CAI and their poweraid throttle body spacer, all for under $1000. that is they way i would go.
once you have lowered your gears, and gotten a CAI and throttle body spacer, then consider the exhaust and jet chip (stage 2 chips are for vehicles that have modified intake and exhaust).
With the chip addon stage 1 or 2. Do you find or does the manufacter suggest to run the higher 93 octane fuel? If yes, I would think the higher priced fuel would off set any mileage gains. But the extra hp & torque would be graet for towing.
I felt a slight improvement with first a stage1 Jet kit and then with the Airaid CAI. The CAI makes most of it's power differences in the upper ranges and the stage1 had more of an overall slight improvement from stock.
I don't know... I have 4.10's with my 33's and I'm ready for a deeper set. It really seems to struggle with what gear it wants to be in at around 60-70 mph, so highway driving is most definitely a pain. My only concern is that it'll really go south if i go any deeper than 4.88's, what with the engine being all wound up all the time and all. I need to hurry up and pay this sumbitch off so it can get a V8.
4.10 gears on 37"s? he says it's fine now...until he regears.
i agree. with 33's, the gearing should be 4.56 or deeper. we aren't offered 4.56 yet...so, there you go. but i think that would be a good balance. if you are doing a lot of towing, then those little "nickel and dime" bolt-on HP things aren't going to help you at all. without the extra load, you may notice some throttle response, and your jeep might see a pony or two (if you can even notice gains that small), but not with a trailer behind you.
