Best quality and reliability winch that's not a Warn
Old Apr 12, 2013 | 08:08 PM
mudbug79's Avatar
I have been running a XRC8 for about 5 years now. It's been great.
Old Apr 12, 2013 | 09:39 PM
Redman333's Avatar
How do you know what size/capacity winch to get. Say 8k or 10k or 12k. I assume a 2 door would be fine with a 8k but will it be too small for a 4 door etc? Does it depend on how heavy your jeep is?
Sent from my iPad using Tapatalk HD
Old Apr 12, 2013 | 11:24 PM
gunbo75's Avatar
Its 1.5 times the weight of your Jeep so I have a JKu and i have a 10,000 warn on mine.
Old Apr 13, 2013 | 03:22 AM
catahoula's Avatar
Anybody have experience with brands like Quadretec, Rugged Ridge, Harbor Freights?
Old Apr 13, 2013 | 03:29 AM
carolinajk's Avatar
superwinch lp8500 or lp10000 also superwinch tigersharm series . ck them out too . name brand and affordable
Old Apr 13, 2013 | 03:38 AM
scratchkenny's Avatar
Originally Posted by Jonathan_JK
Ill Keep this short then
Recon 10500
x2 I got the same one, from truck and winch
Old Apr 13, 2013 | 04:06 AM
phljeeper's Avatar
X3 on Recon. Great winch. Works great and includes synthetic line.
Old Apr 13, 2013 | 04:14 AM
catahoula's Avatar
Jonathan is yours a 10,500 pro performance waterproof? Saw one on Amazon for @ $439.
Sent while sitting in my Jeep using JK-Forum
Old Apr 13, 2013 | 04:33 AM
scooby snacks's Avatar
I have an Engo and it has served me well or should I say all the others I have pulled out?!
Old Apr 13, 2013 | 04:46 AM
CJ8's Avatar
CJ8
A JKU is around 4,000lbs ( don't know about the 2 door). 4,000lbs X 1.5 = 6,000lbs. So they say a 6K winch will do. I disagree. Sure you can use snatch blocks ect to help the winch, but it has been my experience that with winches bigger is better. I have run a Warn HS9500i for years on my Scrambler. There have been times when it has struggled to get me or someone else out (stuck bad). On my JKUR I went with the Warn Zeon 10K. When choosing a winch there are a lot of factors to look at; current draw, recovery speed, reliability ect. I know the OP said not to mention Warn, but Warn was, is and will be my only winch option unless something better emerges. The way I look at it is if it comes to me needing the winch then I am in a bad way. I don't want to have to worry if the thing is going to work. I have seen situations where a failed winch can result in major vehicle damage or injury (roll overs ect). My advice is save your money just a little longer and get the Warn. Before you beat me up I know there are lower cost decent winches out there but IMHO I would rather spend a little more for the piece of mind.
