Best rock rails for using as a step
Old Jul 28, 2012 | 11:41 AM
ramy's Avatar
Originally Posted by treid
a question to all the ace supporters, any problem with length of these on a 2 door and tire rubbage?
Not at all. I had to trim the Rubicon rock rails because of rubbing but the ace are about two inches short in the front and rear so there is no problem.
Old Jul 28, 2012 | 01:45 PM
kosmos's Avatar
I use my ACE sliders (even put some no-slip on them) everyday - work GREAT for a step up...
Old Jul 28, 2012 | 02:18 PM
Dagley918's Avatar
Yup ACE rails for me.
Old Jul 28, 2012 | 07:05 PM
Jhen's Avatar
ACE!
Name:	ace resize 1.jpg
Name:	ace resize 2.jpg
Old Jul 28, 2012 | 07:26 PM
DKehler's Avatar
I chose White Knuckle. Frame mounted and stick out the same as the fenders, which is a little more in the front.
ID:	346869   Click image for larger version
ID:	346870   Click image for larger version
ID:	346871   Click image for larger version
Old Jul 29, 2012 | 01:58 PM
thegoat's Avatar
Default Poison Spyder Customs Brawler Rockers
I have the Poison Spyder Customs Brawler Rockers and love them! Add some wing Walk compund or grip tape to the top for a non-slip surface.
ID:	347136Click image for larger version
ID:	347137Click image for larger version
ID:	347135Click image for larger version
Old Jul 29, 2012 | 02:31 PM
jeepsta's Avatar
I have the smittybilt src took a whole 25 min to install by myself.
ID:	347159Click image for larger version
ID:	347160Click image for larger version
Old Jul 29, 2012 | 03:28 PM
mrmike's Avatar
Does the ACE frame mount? I'm looking at either Ace or LOD myself.
Old Jul 29, 2012 | 03:42 PM
keithvegas's Avatar
Ace has two versions of the same rails. One is bolt on and the other has the rails without powder coat plus the cut pipe, plates and gussets to do a weld on.
Old Jul 29, 2012 | 03:57 PM
Freewill's Avatar
Attachment 347136Attachment 347137Attachment 347135Attachment 347134
X2. Brawler is a kick-ass rail with a great mounting system, and the flat top makes enough of a step that my wife can use it when needed. They are so solid that I've stuck the jack nose into one of the holes and lifted the whole side of the Jeep. As you can see in thegoat's photos, they look good too.
