Best spark plugs?!
Old Dec 30, 2012 | 01:51 PM
5150cliff's Avatar
Originally Posted by JKJeepJunkie
If your worried about gas consumption caused by the spark plugs its because they are worn out and aren't sparking like they should ive recently changed mine and ive noticed better mpg and its alot smoother idle and take off im running champion iridium the factory OE is a double platinum but you can't gap a fine wire platinum plug just stay away from Bosch plugs and E3 plugs and NGK's and you should be fine
Why can't you gap a fine wire plug? I bought the Champion Double Platinums and they gapped perfectly. Did I miss something?
Old Dec 30, 2012 | 02:03 PM
StuFarmer's Avatar
The O.E.'s seem to work the best.
Old Dec 30, 2012 | 02:54 PM
winkelhawk's Avatar
I have had really good results with Denso Iridium. I have the Autolite Iridium in the Jeep now and the truck runs good.
Old Dec 30, 2012 | 05:02 PM
Ryan0260's Avatar
I would stick with factory
Old Dec 30, 2012 | 05:33 PM
burnout88's Avatar
NGK Iridium Ix plugs are what I run. I installed them in JK. Very nice quality plugs. Champion makes some serious garbage plugs.
Old Dec 30, 2012 | 06:22 PM
JKJeepJunkie's Avatar
Because the fine wire plugs the di-od is so brittle that when you gap them you chip tiny pieces off you won't be able to see them but it happens and it changes how it sparks somehow i had to take a class on all this working for orielly auto parts
Old Dec 30, 2012 | 08:35 PM
MrHooah04's Avatar
Thanks for all the great advice..just trying to pinpoint the problem. I only have 33's and the TF 2.5" Coil lift and I'm at 13 mpg..I've got an 07 jku auto, just seems way off for my 4.10's. it also idles rough so that's why I'm wondering if my plugs are bad or not.
Thanks all, keep the advice coming!
Old Dec 30, 2012 | 09:13 PM
suds1485's Avatar
What engine do you have? How many miles? How long has this been going on? What kind of maintenance history does it have at what interval? What service are you due for? What kind of gas do you run? What's you driving conditions (such as environmental)?
Old Dec 30, 2012 | 09:24 PM
5150cliff's Avatar
Never thought of that.....
Old Dec 31, 2012 | 04:41 AM
snakeyes76's Avatar
copper plugs are the best plugs you can use. they conduct the spark better and are less likely to overheat. Gapping will have to be changed as is not the same as the stock specs
