better tires
Old Nov 15, 2008 | 11:06 AM
jerzeyjeep's Avatar
Default better tires
well i am tired of getting stuck with my all terrians
i have extreme all terrains from procomp and as they are great on the road they suck in the nj slop.
i am looking at Pit Bull Rockers. i know they are bias ply but these will prob be my offroad set only.
any other opinions on tires like these or of the Pit Bulls themselves
Old Nov 15, 2008 | 11:10 AM
Goldorak's Avatar
if it is for mainly off-road use , Interco's TSL is the way to go
Old Nov 15, 2008 | 01:28 PM
ZoSo-Green's Avatar
X2 on the Swampers
I've seen those tires do amazing things in slimey So. IL clay.
Old Nov 15, 2008 | 01:40 PM
jerzeyjeep's Avatar
i still have to get to the trails. i am not a fan of the boggers myself.
here are some of my choices
PITBULL
IROK
TSL
any other suggestions in the same range would be greatly appreciated
Old Nov 15, 2008 | 02:11 PM
ZoSo-Green's Avatar
The Pitbuls are pretty cool, But if I had the chance to buy an off-road only tire
The TSL's would be my only choice.
One time in particular stands out in my mind...
A stock 90's model S-10 4x4 in a empty (harvested) field, buried up to the frame...
The Swamper's dug down... found a hard spot... and we drove right out.
The guy behind us had generic M/T's (Courser I think) and had to pulled out by a tractor.
Old Nov 15, 2008 | 02:15 PM
jerzeyjeep's Avatar
sweet well then that sways my decision a little. has anyone else had any knowledge of these tires besides what the manufacture has to say??
Old Nov 15, 2008 | 02:25 PM
Stuka's Avatar
The Iroks are superior to the TSL's in most cases. But if its mostly mud only, go with the TSL's. I have been running TSL's for many years on my other Jeeps, and I love them. The Iroks have a better compound, as well as more biting edges. So they excell in areas where the TSL isnt quite as good. However, the Irok is limited as far as smaller sizes go.
Since you are running 16" wheels, you choices are a lot more limited for both when compared to a 15" wheel. Be sure to go to Interco's website (intercotire.com) and look at the actual sizes of each tire.
Old Nov 15, 2008 | 02:30 PM
jerzeyjeep's Avatar
i have noticed that i am limited to the size of the rim. it wouldn't matter to me the rim size cause i will prob have to buy new rims. 15 or 16 inch and alloy of some type. haven't had much luck with steel wheels balancing well.
as for just mud, there is allot of sand here also and hopefully snow.
this is going to be a christmas present to myself so the more opinions the better
this sight rules!!!!!
Old Nov 15, 2008 | 02:53 PM
Stuka's Avatar
If you may be in snow, go with the Irok, it does a lot better in the snow. As for steel wheels not balancing as well, that really wont matter if you run a bias ply tire. As most tire shops will not balance a TSL or the like. I have never run any weights on mine, because no shop here will balance them. And steel wheels have a safety bead, so you can air down lower without a risk of blowing off the bead. And they endure abuse better.
Old Nov 15, 2008 | 03:01 PM
jerzeyjeep's Avatar
alright now we are getting somewhere.
so lets go with 15' steelies
i have one vote for iroc and one two votes for tsl
keep the coments coming i don't want this to happen again
i hate being pulled out
