The big 3 or rather 4 electrical upgrade
Originally Posted by kejtar
If you wriggle the shifter to start that sounds like the neutral safety switch which is different.
Funny this post came up. Just ran a wire from the battery negative to the alternator bracket. I have no idea if this is correct. I am hoping that it fixes my no start issue. If this does not work and fix my no start I will have to replace my WCM. Transmission range sensor "passed" testing as I had them check it when they did the rear main seal. I say BS and they never actually checked it when they did the rear main seal but I'll never know for sure. Here are some pics. Hope this $8 fixes if. So annoying to drive a vehicle for 120k and never know if this is the time it doesn't start.
The loop you're looking at is the alternator battery charging loop when simplified would looks like this.
1. Alternator output terminal > Load/Batt B+ terminal (The load is your battery being charged)
2. BATT POS terminal > Internal Battery connections, BATT Neg terminal (you can't upgrade this)
3. BATT Neg terminal> Chassis
4. Chassis > Alternator input terminal (bracket/chassis)
5. goto step 1, repeat
With your fix attempt, you made a direct connection from the Batt neg terminal to the Alternator input terminal. The items I have in orange TEXT within the loop.
If you still have the same results, you may want to add a similar size wire from the Alternator output terminal, to the BATT B+ terminal, so you have essentially completed upgrading the entire loop path.
It's just this basic circuit loop.
You just made the wire thicker between the (-) connection on the voltage source "V", while leaving the wire between the (+) connection of V to R the same size. Thus, upgrading half of the loop.
The most common fix for the click-no-start issue was the larger wire from the alternator bracket (engine) to the battery negative terminal. I can see a wire from the alternator bracket to the frame being a waste of time, as mentioned above, but the benefit from running one to the battery negative terminal has been demonstrated to be real. It has worked well for those whose problem was inadequate grounding.
Personally, if I had that problem I would have started with doing the Big 3 upgrade, and based on what was found to be a fix, beefing up the wire from the NEG of the batt, to the chassis may have fixed that problem as well. Do you know if anyone tried fixing it with the Big 3 upgrade or by running a thick wire from the batt NEG to the chassis?
EDIT: Here's some good background info on circuit breakers performance parameters that any competent engineer will consider before inserting one to replace a fusible link ...
https://www.mikeholt.com/mojonewsarc...s~20030621.htm
So far just simply running a new 4 gauge ground to the alternator bracket has worked. The day of this repair it happened twice. Now the no start issue has no longer happened. It's only been a few days but as someone else mentioned it really does sound like a stronger engine start and the horn for the alarm seems to respond faster when I press the button.
Sure it could be all in my head but I got the JK with 8 miles on it and now it has 119k. It's done if from year 2 and on and I've just accepted it, tapped the shifter or even just moved it into N and it always started right up. Never left me stranded.
But people with minimal mechanical experience can easily complete just the negative to the alternator bracket in under an hour time.
It will save them $400 because the dealer fix is a new Wireless Control Module (WCM) and many have reported this has fixed it. But the dealer I personally feels like they already know this especially since there is a TSB out there on the WCM. I feel they put people through the works first with a new battery, new starter, new wires from the starter and then after you have spent a few hundred they do a WCM and the issue is resolved.
So far this works. Subscribe to this post and I promise to update it if I ever get a no start again. I also promise to do the WCM after that and see if that fixes it once and for all. I want the answer out there for everyone to know. I take my JK deep into Baja and it really sucks to get the no start issue in the middle of nowhere with no one around.
I read through the material at the link and I am not necessarily getting why not a circuit breaker.... I got the circuit breaker from my local electronics shop and while those guys don't build cars they do know their stuff. I explained the application thoroughly.
What I would be curious to find out is if you just ran the same 4 Gauge wire from the NEG post of the battery to the same point on the chassis where the neg terminal is already connected to the chassis. Your fix is technically, the same thing, in that when you ran that wire, you increased the diameter of the wire from the NEG battery post, to chassis ground, thus increasing the electrical system's max current delivery capability. The alternator chassis, is connected to the vehicle chassis, so electrically speaking, connecting one end of the wire to the chassis or the chassis of the alternator is the same thing. I have a 2009, and have had the big 3 wiring on since 2010. I have never experienced this problem. Maybe that's a big reason why?
Originally Posted by Rednroll
Glad it worked.
