Bikini Top Question
So I'm looking into purchasing a bikini top. I know it requires a windshield header, but I was just wondering if the bikini top is waterproof. Does it let water go through it?
and then once you get it on.. youre going to want to get a top prop and a tonno prop.
lets just call it water resistant. also.. not only do you need the windshield channel.. but you also need the door surrounds.. the bolts for the surrounds.. and the tailgate bar and clips...
My recommendation - go with the Sun Bonnet from mopar. It's more expensive but comes with the stock header already attached and seems to get better reviews then the plain ole' Bestop. Just make sure if you have an '10 or newer you get the hard top version because your soft top door surrounds will not work with the soft top version.
1. Mopar softtop Sunbonnet (silly name for their safari top). Bestop makes one, but Mopar is better. Yes, it's lots more expensive, but it's worth it. The header bar is built into the Mopar version, so you don't have to buy that also. Do be aware of model year changes in how the tops mount--make certain what you get works with your year of Jeep.
2. Door surrounds. If you don't own a softtop, you'll want to buy these.
3. Bestop Duster with mounting hardware (tailgate bar and clips, which if you already own a softtop you'll already have). This will keep your tub area dry.
4. A Bestop Windjammer, which will leave some of the back open to the worst rain or when parked, or a TWO-DOOR (since they don't make a four-door) WRAPAROUND Windjammer, which will seal the back better. You will have to stretch it to force it to fit. You can also modify a regular Windjammer to add more material to seal up the openings.
5. A Bestop Trail Cover to throw over everything when parked. Works great with/without doors and with/without top. Even can be made to work with hardtop and no doors.
Look here for tons of pictures and information on safari tops ...
https://www.jk-forum.com/forums/showthread.php?117145-best-safari-top/page1
