Bilstein 5100s for 3" lift?
I need some help from the suspension experts around here. Just purchased the Full Traction 3" Economy Plus lift and need to know what shocks I should be ordering. I'm positive that I want Bilstein 5100s but need some advice on which ones. I know this kit nets more than 3" by reading around on the forum, so should I go with the ones for 3.5" - 5"? Below is their part numbers and my two options:
I have the same lift with bilsteins. Just installed my 37's today and got death wobble all bolts are tight and the adjustable track bar in the front is bowing. Can your check yours and see if it's doing the same? When parked jiggle the steering wheel side to side and have someone watch the bend on the track bar it bows/ flexes... Or has anyone else having this problem it scars the crap out of me definitely not safe!!
I've ran this same bar for 40,000 miles on my JK. I can assure you it's safe. What torque specs have you set the bolts at?
