BL--- any issue i must knew before install?
Old Oct 25, 2009 | 12:39 PM
uge's Avatar
uge
Default BL--- any issue i must knew before install?
i´m waiting for a 1" Body Lift and a AEV Snorkel.
is it necesary to disconnect the batery before lift the body?,..
i had read that it´s necessary to disconnect the batery to avoid problems with the airbags.
Old Oct 25, 2009 | 01:22 PM
ricrac12525's Avatar
check out the post post titled "weird body lift problem" just above yours.
Old Oct 25, 2009 | 03:11 PM
Yoda's Avatar
Yes you should disconnect the battery
read this: xxx.performanceaccessories.com/instructions/991.pdf
Old Oct 26, 2009 | 01:58 PM
uge's Avatar
uge
ok, thanks so much, this is exactly the BL i purchased. I´ll desconect the airbag before start the install.
Otherwise, i´m thinking that there would be a little gap between the grille and the front bumper, isn´t it?
Old Oct 30, 2009 | 01:17 PM
btblevins's Avatar
As a general rule it is normally wise to disconnect the battery before doing much of any modifying on a vehicle, anything electrical is a no brainer, but when your messing with the frame (or anything else that MIGHT have a ground strap nearby) the extra minute and a half (if that) to disconnect the battery is just plain worth it.
