Black Diamond 2" Lift
Old Jan 20, 2010 | 12:55 PM
Nigel's Avatar
Default Black Diamond 2" Lift
Sometime in the near future, I plan on lifting my JK with a coil spacer kit. I've been looking at the 2" kit from Black Diamond. I've been reading-up on installation of the kit, and I have a few questions.
First of all, will I need to buy anything other than the actual kit? According to JC Whitney, " 2" Kit includes: 4 thicker coil spring isolators to replace the factory isolators on the front and rear springs. 4 new suspension travel-stops prevent over-compression. Easy to install 2" spacer lift kit allows use of original shocks for added value. "
Also, will I need to relocate the brake lines? Will I need to buy an adjustable track bar? Anything else?
Old Jan 20, 2010 | 04:39 PM
nangulator's Avatar
I would suggest getting th AT shocks as well, at 2 inches your brake lines should be fine.
Old Jan 21, 2010 | 03:10 PM
Nigel's Avatar
Actually, I'm planning on getting the Rancho 9000XL shocks which allow for up to 2" of lift. So I won't need to buy extenders or anything. Thanks for the replies!
Old Feb 23, 2010 | 08:48 PM
fluent's Avatar
just ordered the black diamond 2" tonight, im pretty stoked.
Old Feb 24, 2010 | 03:26 AM
IcyFridge's Avatar
Post pictures when done!
Old Mar 16, 2010 | 09:46 PM
fluent's Avatar
so I got the kit today, won't be able to put it on for another 2 weeks (no time)
but Ill post pics/writeup fo'sho.
ps if someone can link a thread for a coil spacer write up that'd be great, otherwise I'll just use a case of budweiser and some reading glasses.
Old Mar 17, 2010 | 04:13 AM
mkjeep's Avatar
http://project-jk.com/jeep-jk-write-...ation-write-up
https://www.jk-forum.com/forums/jk-write-ups-39/rough-country-2-1-2-lift-w-rcx-2-2-shocks-install-29671/
Old Mar 17, 2010 | 09:56 PM
fluent's Avatar
thanks mkjeep!
Old Mar 18, 2010 | 04:19 AM
mkjeep's Avatar
Your Welcome!
