Black diamond 3" looks good.
Ive been searching the web and this forum and im having trouble finding any negitive coments about the Black Diamond 3". The only thing ive seen afew times is, some people have added front lower adjustable control arms. I didnt realize you could just add the front lowers..Am I reading that correctly? I hope to hear from anyone who is or has used this suspension system. And someone let me know if im am mistaken about just buying this kit which comes with an adjustable front track bar and adding some adj front lower control arms..Hows the ride on and off....how was installation....anything missing from the kit????Thanks as always
Yes you can use just front lowers on the front, but I also recomend rear uppers to correct your rear axle angle. Depends on if you have a 2 or 4 door. I never had an issue with my rear re-location bracket but I eventually welded in a gusset, just in case. Nothing was missing and the Superlift tech support is great if you have any issues. Great ride, I have the Bilsteins so I don't know about the standard shocks. If you don't get adjustable lowers it may seem a little flighty because of your castor.
YES WITH ADJ.LOWER CONTROL ARMS AND TRACK BAR YOU CAN DIAL AXEL CENTER AND CASTER PROBABLY TO BETTER THAN STOCK DRIVABILITY.THE BLACK DIAMOND/SUPERLIFT STEERING STABILIZER IS 1ST RATE.I DID TRY BLACK DIAMOND SPRINGS ON INITIAL LIFT(replaced with TERAFLEX way smoother ride.AND HAD NEGATIVE CUSTOMER SERVICE EXPERIENCE WITH B.D.TRACK ARM SHOWING UP MISSING PARTS.SO MAKE SURE YOU CHECK FOR HOW WELL COMPANY SUPPORTS PRODUCT WHEN MAKING DECISION.DO YOU HAVE 2 DOOR OR 4 MIGHT WANT TO CONSIDER CONTROL ARM FOR REAR(driveline angle)IF 2 DR i ran stock rear driveshaft for a long time with 4"lift and rear control arms with no problem on 2dr
