On-Board Air Compressor?
I took a look under the hood of my JK last night to see where I might be able to mount a small compressor. I didn't come up with much. The only real space I could see was in front of the battery, but it's not quite big enough. I think I'm going to give up on the hard-mount option for now. I may go with a portable unit like the Viair 400P. If someone else comes up with an idea of where to hard-mount one under the hood, I'd love to hear it.
I mounted a Viair air compressor very simular to the one you are looking at..I mounted it on the u shaped channel the runs below and across the frame ends behind the front bumper..But I have an aftermarket bumper and a winch not sure how it would work with a stock set up...Here's a couple pic's
I'm clueless!! No room, in the engine compartment for a 2.5 gallon tank..
You can always mount that portable air tank on your rear rollcage with quick release straps..
I don't have a reserve tank..the compressor I have(Viair 380) will pump 200 psi at 50% duty cycle and 100 psi at 100% duty cycle. It takes about 10 mins to pump up 4 35" tires from 10 psi to 30 psi...All I use it for is to air up so I can live without a tank.
Try JCWhitney...part# ZX148930U.
I have a similar unit that i plan on installing in the next week or two. I'll post some pic once installed. This tank is small enough to mount above the t-case skid plate or IN the front bumper. I've already test fitted now i just need to do it. The compressor I have is small enough to mount between the battery and main fuse block under the hood.
It's great for tires and air mats!!
<img src="http://www.jcwhitney.com/wcsstore/jcwhitney/images/imagecache/I_148930_CL_1.jpg">
http://www.walmart.com/catalog/produ...roduct_id=3992
What about something like this? i just need something to air-up after the beach. Can it handle 4 33" tires?
