Body leveling...
Old May 17, 2010 | 06:15 AM
Hotspur's Avatar
Default Body leveling...
OK, so I'm new and need some help. I want to level the body of my '10 sport. I have read several threads about it but am still unsure what I need to do. Just buy a leveling kit and if so, whose? Leveling kit and springs? Not looking to lift anything yet, just level. All help is appreciated (sp).
Old May 17, 2010 | 06:28 AM
shogunn's Avatar
Default Re: Body leveling...
If you just want to level your rig all you need is a 3/4 to 1" spacer for your front coils. You can get those for about $40 from teraflex or daystar. Another option is the teraflex leveling kit. It runs $160. I just put one in last Friday. Took a couple hours with hand tools. I'm no mechanic either. It will raise your front end 2" and your rear by 1". Levels the rig and gives it just a bit of lift. Looks great. I'd post pics but I haven't taken any yet. The tf leveling kit along with some spidertrax wheel spacers really gives a stock jk a more agressive appearance.
My 2 vents.
Old May 17, 2010 | 07:32 AM
wazooz2424's Avatar
this...http://northridge4x4.com/proddetail....953075&cat=273
OR this....
http://northridge4x4.com/proddetail....155200&cat=272
the second option will give you a better stance and level it out. i would opt for option 2. 119.00 shipped from northridge4x4.com.
Old May 17, 2010 | 10:06 AM
Hotspur's Avatar
If I go with option 2, it is offered with "front disconnect hardware" for $50 more. What is that and do I need it?
Old May 17, 2010 | 10:22 AM
wazooz2424's Avatar
if you plan to offroad, you will want to disconnect your front swaybar when on the trail. the disconnect hardware allows you to do this without tools. i would forgo the $50 TF hardware and get some JKS quicker disconnects.
Old May 17, 2010 | 10:29 AM
Hotspur's Avatar
Alright. thanks for the info. I looked at the install sheet at tereflex...how long does this take using hand tools?
Old May 17, 2010 | 11:28 AM
JKRINGO's Avatar
There's a lot of opinions on the best/fastest way to do this install and here's mine. Devote an afternoon to it and ask a friend or two for help in return for a couple beers. Check that you have wrench's,jack & jack stands necessary and most of all BE SAFE!
Old May 17, 2010 | 11:31 AM
wazooz2424's Avatar
with hand tools and without a helper, you are looking at 3-4 hours. with a helper, maybe 2-3.5 depending on skill level. it is not a hard job, just time consuming.
Old May 17, 2010 | 12:16 PM
gaspasser's Avatar
Default Leveling Kit
I have had the Teraflex leveling kit on my 2007 for over a year and no problems to report so far. Love the look, completely leveled it out, even with a LOD midwidth bumper and winch sitting on the front.
Install took me around 6 hours working by myself. It was not hard, just my first time doing any suspension work. Needed to use a pry bar to get springs in and out, probably the most difficult part. Would have been easier with a spring compressor, which I think you can rent, but I got it done without. Make sure to droop the suspension as far as you can. I removed the brake line from the supports front and rear to get as much droop as possible.
Good luck.
Old May 17, 2010 | 01:04 PM
PeterWendy's Avatar
https://www.jk-forum.com/forums/show...x+leveling+kit
This is a great thread. Searched for "teraflex leveling kit questions"
tells all the tricks and traps
I still can't find my camera though
