which body lift
ok so i have a '10 base manual jk... i already put a 2.5 rough country spacer kit with the brake line relocators... i am running 35 x 1250s and im scrubbing on the fenders some... i was looking into a body lift and i am trying to decide on what size to go with... Ive found 3 different ones im interested in. i talked with a guy at Rough Country and he said there wouldnt be a problem running both the 2.5 spacer kit and the 1.25 body lift... i think a 2" would be too big since i already have the brake lines extented... and i will have to bend the shifter... the 1.25 will work but i will have to bend the shifter (supposedly what the guy from RC said) and with the 1" it will work with no problem...
any input or experience would be much appreciated |
if you rub on the inside of the fender just add on tire spacer 1.1/4" i have a 2.5" skyjacker with 3/4 spacer on 35" i don't rub one bit even on flex
post a picture up to see exactly what's going on |
Originally Posted by saltine
(Post 1662077)
its not rubbing while driving normally... its only driving when flexing... and if i hit a giant bump... im running crager soft 8s with a 4" backspacing as well... its not really to solve the rubbing... im trying to figure out which body lift would be the best for me... either will work... im trying to figure out if one lift or the other will over flex the brake lines... im leaning towards the 1.25" Rough Country lift tho
Originally Posted by mkjeep
(Post 1662144)
A body lift has nothing to do with your brakelines, you don't bend your shifter either, there is a shifter boot you have to trim on a manual.
If you have a 6 speed the RC 1.25 wont work.
Originally Posted by jvalason
(Post 1662215)
