Body lift?
Old Oct 14, 2008 | 05:23 AM
snosurferjeep's Avatar
Default Body lift?
Looking into a 1" body lift any suggestions? Pros/cons one vs another. Also looking into a spring spacer 3/4"
Old Oct 14, 2008 | 05:31 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I happen to have the Perf Accesories one on mine & couldnt be happier with it.
Performance Accesories: The pucks are type of plastic
M.O.R.E.: The pucks are aluminum.
Other than that, not much difference except cost as far as I know.
I opted for the plastic pucks being from the salted road state~figured they would withstand it a little better. Not much different, but maybe a little.
Old Oct 14, 2008 | 05:35 AM
freshjk's Avatar
I have been looking into a body lift as well!! Whats the best body lift??
Old Oct 14, 2008 | 05:39 AM
Eternal ***erator
Beats me. as far as I am concerned they are all basically the same, none any better than the next.
All it is is a stack of pucks and some longer bolts.
Aluminum vs. Plastic.
Pick one. I know people that have both, they both work just fine and do exactly the same thing. I went with price, and leaned towards the plastic to avoid corrosion, but i really doubt it matters, I have aluminum wheels/spacers/etc. and that stuff is fine.
Old Oct 14, 2008 | 01:21 PM
mkjeep's Avatar
1in MORE here, no probs , easy install.
Old Oct 14, 2008 | 03:16 PM
zxqwertyxz's Avatar
I did the 1" DayStar. The pucks aren;t round cylinders. The conform to the shape of the mount. I di dth einstall with my 11yo in a couple of hours. No silver pucks to paint either. Great customer service too.
Old Oct 14, 2008 | 03:30 PM
Nozz's Avatar
1" shouldn't matter much. most kits are the same. the kits with aluminum pucks I have heard ride a little harder but I don't know. I know they cost M.O.R.E. so when I get mine I will buy "plastic" which are usualy nylon or a composit.
Old Oct 14, 2008 | 03:34 PM
mstay4's Avatar
in my old truck I used hocky pucks, they worked fine, but on the jk i'm gonna buy a kit... most likely plastic
Old Oct 14, 2008 | 10:23 PM
aldaman's Avatar
x2 have the MORE as well...It all boils down to your preference....Love the MORE & the install was a breeze...
Old Oct 15, 2008 | 05:06 AM
GadgetFreek's Avatar
PA 1" here as well. For me it came down to cost. The PA was the least expensive and they build body lifts for tons of different applications (i.e. lots of experience as well as r&d)
My only beef - with all body lifts is how much more would they have to charge to send me 12 new washers instead of making me beat them off the body mount bolts. Not only is it time consuming but in most cases you end up ruining the stock body mount bolt because you are hammering the tapered end...... Just something that is frustrating. Really, how much could 12 washers cost? [/rant]
I am really happy with the end result though.
