bodylift is one better
Old Jun 20, 2010 | 04:13 AM
cdryanhall's Avatar
Default bodylift is one better
is the daystar better then all the others its 200$ and i have found some around 100$. so is one better then the other and if so how thanks
Old Jun 20, 2010 | 05:02 AM
JMP8562's Avatar
I have the M.O.R.E 1" body lift and i went with that due to they are aluminum and not rubber / poly type material i think they will last a lot longer
Old Jun 20, 2010 | 05:37 AM
cdryanhall's Avatar
thanks for the help i have been looking around the site and found that if have the 6 speed and the 1.25 will not work so thanks
Old Jun 20, 2010 | 08:25 AM
ethang1977's Avatar
most of the bodylifts are made from plastic. technically its glassfilled nylon. the strength rating is unreal and takes a million years to degrade.
Old Jun 24, 2010 | 05:04 PM
chad s's Avatar
Just installed a daystar w/6 speed and no problems. Ordered mine from Quatratec for $169 w/ discounts and free shipping.
Old Jun 24, 2010 | 06:04 PM
I have the Daystar one as well, but when I FIRST installed it, it would pop out of second gear. It stopped doing it after a while and it only happens once every so often now. Not to big of a deal, just have to make sure its ALL the way in second gear.
