Bottle jacks.
With 35s, the stock scissor jack doesn't cut it. I'm deciding on a new jack to buy and I'm thinking of grabbing a 6 ton bottle jack.
My question is, what is everyone using as a lift point for their bottle jacks? I know it's on the axel, but with a head the size of a quarter, I'm worrying about the stability of a bottle jack on a round surface.
And I know someone is going to suggest off road swag's bottle jack adapter, which is pretty cool, but I want to know about off the shelf bottle jacks.
I use the bottle jack in the same spots I used the scissors jack. I don't remove the wheels or go under the jeep until there are some jackstands under it. I still haven't had to use the bottle jack on the trail though.
I got one, but with extended sway bar end links I have to lift the front bumper way too much to get the axels to lift off the ground.
I feel this is safer b/c you are lifting by the axle so you don't have to lift the entire jeep nearly as high b/c you aren't fighting the axle droop. This would be especially true off-road if you had your sway bars disconnected.
