Brake boosters?
Going up in size on my tires has killed my stopping power. So I'm about to order front and rear Teraflex performance big rotors kit and hawk pads (lts). My question is should I do a brake booster also and am I buying the right kits??? Maybe mopars j8??
My JKUR, auto, 4.5" MC lift, 35" tires (soon to be 37s) and 2" wheel spacers.
Just a heads up, there was a set of the Teraflex caliper relocation brackets on eBay at a reasonable price, then you'd be able to add the pieces you'd like without paying the extra premium.
The master cylinder issue comes down to what year jeep you've got, it seems somewhere in the fine print there are jeeps that didn't need a larger cylinder. Also, member Ringer found a Raybestos that matched that "upgraded" cylinders, but that info has been a few years back.
I went with front/rear Teraflex rotors/brackets, 08 jku auto on 37's. Works great for my use, I don't feel the need for the upgraded calipers/booster at this point. But we all have different opinions and needs, so only you can decide. Also, I went with those hawk lts pads based on the great reviews at the time. Lots of brake dust. They work fine for me, just lots of dust. If you look for newer reviews, it seems to be a common gripe.
The other option for rotor upgrades is Dynatrac. At the time I bought, their kit was about $350 more expensive than Teraflex rotor kits + pads. I couldn't justify the cost difference. (and I think the price on the dynatrac kit was raised another $100 since then...)
If you talk yourself into calipers, the Mopar kit is priced fairly well, and includes the master and lines and everything. Last I heard it is front only, not sure if there is a rear option yet.
I considered upgrading the calipers, but I like the option of going to the neighborhood auto store and get some pads if need to. I know with the mopar kit I cld do that, but they dont offer rears. My OCD (smh) tells me I wont be happy unless I have a matched set.. that's why I picked the teraflex rotor kit to be used with my stock calipers. They had good reviews and price.. lol
I've seen that the hawks are real dusty, maybe someone will give a good alternative??
Hawks are very dusty. I'm trying out the powerstop z36 rears now and I'm happy with them, though I can't say the rears put out the same kind of dust that the fronts do. The rear Hawks were dusty but not as much as the fronts. The irony- the rear pads wear faster than the fronts on the JK so you'd think I'd see more dust in the rear.
UPDATE::: I purchased mopar big big brake kit (using pads that came w kit) and rear taraflex big rotor with hawk pads. I have not installed the brake booster yet, I wanted to drive a while so I cld comment on just that difference. As of now my jeep stops alot better. I feel very confident having to make a quick stop. There is a slight mushy feeling in the brake pedal, but no more than when it was stock. I'm hoping the booster will add the firmness I hear others talk about. Other than that its night and day difference. Worth every penny!
Now let's talk about the install... I installed the mopar bbk on my jeep and the crown bbk on my buddies jeep. Both are nice but crowns brake clips were flimsy and didnt hold firmly to the pad (it keep wanting to fall off and seemed cheap). CAUTION::: If u have modifications to ur front shocks or extended brake lines, be careful about smashing ur brake lines when at full steering lock. U dont want to mess up ur expensive brake lines or loose brake pressure while driving!!
I used the mopar big booster/ master cyl kit on mine when I did the axle swap. I also had the local Jeep dealer bleed the ABS since the system was completely dry when we replaced everything. I'm pretty happy with the braking power and pedal feel.
I'll be installing the Z36 pads in the rear for sure.
Most braking systems are designed with a 60/40 front/rear balance and that's only when they're fully locked up. In typical braking scenarios it's more of an 80/20 split.
Also the Mopar kit includes the MC and brake booster upgrades. Which means there are upgrades to the rears with the Mopar BBK. The only thing your OCD is missing is someone telling you that you need bigger rotors in the rear.
There's many options to upgrade your rears. A set of increased friction pads may suffice if you feel you really need additional braking from the rear but I highly doubt you'll find that to be the case with the Mopar BBK you got.
Also Crown has stated they're working on a rear rotor size increase kit.
I've had the Mopar BBK installed since 2015. I feel it's well balance and haven't felt the need for further rear upgrades. I'ld be interested to hear your experience since you added the TF rear upgrade. When I look at Dynatrac promoting their "balanced" upgrade system and their associated promo videos, I see the rear squating during hard braking, which is NOT what you want from a braking system.
