Brake Light
Old Jan 10, 2008 | 05:18 AM
Richard's Avatar
Post Brake Light
What do I need to do with the two wires from the rear middle brake light since I installed a new bumper and tire carrier. Do I need to hook them up to something? All those who have installed new carriers have done something with them, no? Thanks
Old Jan 10, 2008 | 05:42 AM
SCF's Avatar
SCF
Get a brake light relocation kit before you get pulled over.
Old Jan 10, 2008 | 06:52 AM
wayland1985's Avatar
x2. Don't want a ticket for missing that light...
Old Jan 10, 2008 | 06:57 AM
SCF's Avatar
SCF
In case others are wondering as well:
http://northridge4x4.com/proddetail....PLATELITE-PLUG
Old Jan 10, 2008 | 04:29 PM
Paul R's Avatar
You can always add a third brake light yourself. I picked up a red "Clearance Light" at Pep Boys for $2.99, mounted it to the tire carrier plate on the swingaway, and wired it in using the stock wires (with an extension added to them).
In case you are interested, I opened up the wiring covers on the inside of the tailgate, cut the stock wires from the Mopar connector, and pulled them out all the way to where they come out of the side behind the subwoofer. You will have to remove quite a bit of electrical tape that is wrapped around the stock wiring. I then re-routed them under the carpet, through the drainhole in the bottom of the storage cubby, under the Jeep, and up through the gap between the bumper and the body. I installed quick disconnects in the wires in the storage cubby in case I ever need to remove the swingaway, so that I can do so without having to cut wires. Then they go up the swingaway arm to the taillight. Works great! And, as others have noted, doing this will save you a possible ticket.
