Brake Line Brackets or Extensions?
Old Feb 19, 2010 | 04:47 PM
1230frstap's Avatar
Former Member
Default Brake Line Brackets or Extensions?
I just put the TF leveling kit on the JK and realized that I had a 2 Daystar 3/4" rear coil spacers in the garage. I have a few q's, though.
1. Can I stack the 3/4" Daystar spacer on the TF spacer?
2. If the answer is "yes" to #1, this will make the total rear lift about 1.75" or so...do I need to do anything with the brakes lines then, or will they be o.k.? It seems like there's enough slack in the rear brake lines, but I want to double-check.
Thanks!
Old Feb 19, 2010 | 05:07 PM
nthinuf's Avatar
Yes, lots of people stack spacers. Shouldn't be an issue with 1.75" total.
If the rear lines are too tight, brackets are cheap and easy to make.
https://www.jk-forum.com/forums/modified-jk-tech-2/can-i-see-your-home-made-brake-line-extensions-91799/
Old Feb 20, 2010 | 04:37 AM
1230frstap's Avatar
Former Member
https://www.jk-forum.com/forums/showthread.php?t=91799
Thanks for the link!
