Brake line help with lift
I have the RK 2.5" stock mod lift and love it so far. It did not come with any sort of bracket or line extensions for the brakes. I haven't been able to flex it very much yet but it seems that if I do the brake lines would get very tight. The fronts especially if I run disconnected. What is the best solution to go with, I know there are braided line extensions, there are brackets, etc, just want to know what the easiest / safest way to go without breaking the bank?
Anybody have pics of their brake line routing with the 2.5" lift? I think I've seen that tie strap the line to the springs, but not sure if that's a good idea. Also what they may look like with some flex?
I did the Bilstein 5100 shocks for the 2.5" lift. I thought maybe the brackets would be fine for rear, but am not sure on the fronts. I'm guessing I'll need brake line extensions
I'm running the RC 2.5" kit and couldn't use the frong extender it came with. The hard lines wouldn't bend far enough to match up... at least I didn't feel comfortable bending them that far. They're fine for street use right now but, extended front lines are on order and should be here by the weekend.
https://www.jk-forum.com/forums/show...BB-Lift-Design
I don't have a close-up of the brake lines under flex, but they survived this full droop on Saturday with room to spare.
