brake lines
Old May 24, 2009 | 05:42 PM
thissideup's Avatar
Default brake lines
Extended brake lines are rubbing the back of the tires. What are you doing to hold them back?
Old May 24, 2009 | 06:23 PM
Offroadme's Avatar
i had the problem with the front brake lines aftermarket ones i had put on i used some zip ties. do you have them on the inside or outside he rear sway bar
Old May 24, 2009 | 06:30 PM
rjhoop's Avatar
yea,just ziptie em back outta the way
Old May 24, 2009 | 08:40 PM
ranwitscissorz's Avatar
Mine had a natural bend to them to make a U shape, so I just rotated the connection that goes to the hard line and it pulled the brakeline away from the tire.
Old May 24, 2009 | 08:55 PM
nthinuf's Avatar
Saw a pic a while back using a cheap spring from the hardware store. One end on the middle of the brake line, the other in an existing hole up on the frame. Looked like a decent idea.
Old May 25, 2009 | 05:43 AM
thissideup's Avatar
I like that idea...Want to becarful of putting them in a place that they won't flex with the lift or be riped off the jeep. A spring gives them room to move but holds them back
