brake upgrade?
anybody have any problems with hard braking. i tend to loose control, pulling hard left or right. and steering very limited.
is there anything out there to upgrade the brakes to stop those heavier tires.
I am running 35x12.50's now and although my braking capacity has been reduced a bit, I still have ample stopping power and do not have any of the problems that you have described.
Have you checked your tire pressure up front... ??? Just a suggestion.. A few pounds can make a big difference during hard braking.. Sound like the fronts are locking up harder than they should..
I sometimes get a pulling to one side or the other but it is simply because of the horrible rutted roads around here. On smooth roads, it stops straight and true. Could that be an issue for any of you experiencing problems?
