Broke Weld, Now What?
Old Mar 8, 2010 | 08:44 AM
Topher8668's Avatar
Originally Posted by JungleJeep
Need some help out there. I have a slight death wobble for a little bit. Well today all hell broke loose.
I cant afford a new D30, but I have a Jeep that I cant drive. I took it to Bermont Jeep in Gilbertsville and they dont sound hopeful about getting done under warranty, so I chose to not have them take it in. Any ideas about what to do?
There is no reason you cant get that welded back on for really cheap. It should only take a somewhat experienced welder about ten minutes. I would recommend going to a jeep dealership. DO NOT go to the service department but instead walk around back and ask one of the techs if they can do it for you. Ive gotten away with some easy repairs like yours a few times that way.
Old Mar 8, 2010 | 09:16 AM
RCJeeper's Avatar
This kinda job is a weld shop's dream. So easy and undoubtably stronger than stock by at least double. There's absolutely no reason to take the lift off to get another axle with a weak bracket.
Any competent weld shop would knock this out in no time for not very much money . . . and they'd likely have fun doing it. All steel and easy location.
Old Mar 8, 2010 | 09:41 AM
ssunde1's Avatar
Yea as some have stated i would get the JKS replacement bracket and have that welded on ( you have to remove the stock one anyways for this) then since you have a dropped pitman arm, you could gete the currie relocation/reinforcement bracket added on, its only $50 and it will keep your steering geometry correct. the jks replacement bracket is only $35, to for $85 bucks plus probably $60 or so to have it welded on and your back in business and have a very unlikely chance of having that happen again.
http://www.northridge4x4.com/proddet...od=CE-9807FTBK
http://store.jksmfg.com/merchant2/merchant.mvc?Screen=FAB_168&Store_Code=JKS01&Categ ory_Code=FABParts
Last edited by HappyCurmudgeon; Mar 22, 2010 at 06:22 AM. Reason: REMOVED NON SPONSOR LINK
Old Mar 8, 2010 | 10:06 AM
UGOTKERN's Avatar
You realize he broke off the front brace right?
You dont have to remove the OEM trackbar brace. to install the front JKS bracket.
Old Mar 8, 2010 | 10:18 AM
ssunde1's Avatar
for this
you do remove the OE bracket because its a REPLACEMENT bracket. its not the track bar brace, that you do not have to remove the OE for.
Last edited by HappyCurmudgeon; Mar 22, 2010 at 06:23 AM. Reason: REMOVED NON SPONSOR LINK
ssunde1's Avatar
wait, nevermind im retarded thats for the rear. sorry for throwin out dumb info
Old Mar 8, 2010 | 12:29 PM
Ryanc's Avatar
JKS sells a replacement bracket and it's reinforced too. i would consider getting one of them.
http://northridge4x4.com/proddetail.php?prod=JKS-OGS161
X2 on that. Very stout.
Old Mar 8, 2010 | 02:54 PM
m(a)ce's Avatar
Sorry about the break. It really sucks.
I got paranoid about mine and went the JKS route in the front after I read about some other East Coast guys breaking theirs (boots & RDY4RKS). JKS is solid so far. I'm gonna put the TF bracket on the rear.
Here's blockrockin's thread.
Old Mar 10, 2010 | 03:22 AM
JungleJeep's Avatar
Got a budy coming over tomorrow to reweld the origonal, then he's going to make a custom reinforcement bracket and weld that over the top.
Old Mar 10, 2010 | 05:37 AM
m(a)ce's Avatar
thats great news man.
keep us posted. hope you can still make it to RC for Easter
