Broken front track bar bracket
Old Jun 23, 2008 | 05:52 AM
slimedcj's Avatar
Default Broken front track bar bracket
Ok so does anyone know of a repair or replacement part to fix a broken off front trac bar bracket off the axle housing.
Bmo
Old Jun 23, 2008 | 06:09 AM
slimedcj's Avatar
Normal mig welder work or need some special welder.
Tia.
Bmo
Old Jun 23, 2008 | 06:34 AM
wayoflife's Avatar
JK-Forum Founder
so long as you are getting things welded on, i would recommend that you upgrade to one of these...
Currie Rock Jock FRONT TRAC BAR RELOCATOR KIT FROM JK OFF ROAD SUSPENSION KIT
Old Jun 23, 2008 | 07:07 AM
slimedcj's Avatar
How does this one caompare to the BDS bracket. that's what we put on it with the stock trac bar.
I was thinking about putting the bracket back on and just using an adjustable trac bar and the skyjacker brace.
Any thoughts on that set up????
TIA
Bmo
Old Jun 23, 2008 | 07:12 AM
wayoflife's Avatar
JK-Forum Founder
i haven't installed or seen a bds bracket up close but i can tell you that the currie rock jock setup, is as beefy as can be. here's a couple of shots of what it looks like installed....
Old Jun 23, 2008 | 10:18 AM
slimedcj's Avatar
Thanks for the info and the pic's ordered one up today.
Bmo
