Broken gear oil change?
Originally Posted by public646
Should I open my diff cover to change oil, or I just unplug the drain hole to do it? Thanks for any input
Or, are you saying the gears are now broken in? In which case, if the oil drained doesn't look too bad, no need to remove the cover.
Originally Posted by ronjenx
The title, "Broken Gear Oil Change" kind of sounds like you broke a gear. True?
I changed mine a couple months ago using just the drain plug and it's so much nicer than pulling the cover (which I did Monday night to fix a leaky gasket seal). If the gear oil doesn't look too bad when you drain it, put the plug back in and fill. If it looks or smells bad, pull the cover and do a more thorough job. Seeing how easy it is to change fluids without pulling the cover now, I will be doing so more frequently.
I changed my gear oil in both diffs twice so far and both times I've pulled the covers. You can get away with just pulling out the plug on the front but definitely a good idea to remove the rear cover because the rear gets dark and a bit of sludge that won't drain fully threw the drain hole alone. Besides, I like to see what's going on behind those covers
