Budget Boost
Old Jan 19, 2010 | 08:38 AM
The Swiss's Avatar
Teraflex 2.5" BB up front and Daystar 1.75" in the rear. Leveled my Rubi, which had a severe rake, nicely out. Using this set-up for about 33 kmls now with no issues at all.
Old Jan 19, 2010 | 09:47 AM
relayer4u's Avatar
Originally Posted by bbhockey19
Looks great did you get shocks with that? Do you think 35's would fit
I have Rough Country 2.2 shocks and as long as you run bump stops on all 4 corners 35s should work ok.
Old Jan 19, 2010 | 09:51 AM
BBirish's Avatar
Teraflex 2.5inch budget boost
35x12.5x15 BFG KM2
Old Jan 19, 2010 | 09:58 AM
rcjeep's Avatar
Sponsoring Manufacturer
We offer 3 versions of our 2.5" spacer kit.
Basic, Mid and Premium
Our Mid kit includes: Spacers, Shock Extensions, brakeline brackets, rear swaybar links, rear track-bar bracket. $179.95
http://www.roughcountry.com/jeep_jk_2.html
Old Jan 19, 2010 | 12:48 PM
bbhockey19's Avatar
I am thinking of the RC 2.5" Series II Suspension Premium Set up, But also want to take a look at Teraflex Budget Boost but want to know which ones are similar to the RC
Old Jan 19, 2010 | 01:09 PM
dom7226's Avatar
What size tires will fit with a 3" lift?
Old Jan 19, 2010 | 01:26 PM
ZoSo-Green's Avatar
I ran the 2.5" RC kit and was very pleased.
Upgraded to Progressive Springs and 3/4" spacers.
(on the 2.5" 35's fit with almost no rubbing, lil bit on the fenders while wheeling, )
on 32"s
Old Jan 19, 2010 | 03:02 PM
BBirish's Avatar
you could go 37s with flat flares and some trimming
Old Jan 19, 2010 | 04:46 PM
bbhockey19's Avatar
if I was going with Teraflex BB which one is the best there are a couple of options
Old Jan 19, 2010 | 05:40 PM
Rubi Russ's Avatar
TeraFlex all the way if your running a Rubi. 2.5" BB was complete with Bumpstops , spacers, shock extenders, BRAKE RELOCATION BRACKETS, Trackbar relocation bracket added additional 1" TFlex spacer to front to remove rake. Sets completely level, only other suggestion is to add additional wire to driver rear ABS wire. I added additional 10" to wire after i Snapped it Jeepin. also remove that rear sway bar and WOW does it flex. Acts like a big cat,prowling on all fours.
