building and putting together a kit.
Old Jun 15, 2012 | 02:32 PM
da wrangler's Avatar
Default building and putting together a kit.
ok so i want to build a lift kit my self. here is what it would look like:
evo plush ride 4'' springs
bilstein 5100's, then upgrade to fox rr shocks
rock krawler front and rear upper control arms
rock krawler front and rear lower control arms
full traction front adj. track bar
full traction rear adj track bar
what else?
Old Jun 15, 2012 | 02:40 PM
jaker t5's Avatar
what else?
Skip the bilstiens if you know you want the fox and a tie rod , everthing else looks good you don't have to do all the control arms right away front lowers and rear uppers that way you can move some money over to your shocks
Old Jun 15, 2012 | 02:41 PM
chris@offroadevolution's Avatar
Sponsoring Vendor
what else?
You should consider buying the EVO Enforcer kit, this will give you jeep the best ride and handling you can get with our EVO Plush coils. I would suggest the King Shocks with this kit as they are valved for our coils
EVO: Suspension / Steering, EVO MFG(2) 4" Lift Kit ENFORCER Package
Old Jun 15, 2012 | 02:46 PM
MotiCross's Avatar
what else?
I think it sounds great! you can always upgrade late and sell the existing shocks.
I did fox shox, Teraflex LCA and waiting for the 3" plush coils to come out
Old Aug 24, 2012 | 04:53 PM
TeRC's Avatar
Is there anything else that is needed aside from wheel/tire or is the kit completely everything I would need? Also, is the kit upgradable later?
Old Aug 26, 2012 | 10:00 PM
TeRC's Avatar
Bump for an answer.
Old Aug 27, 2012 | 07:34 AM
Sponsoring Vendor
Front driveshaft for 2 door and 4 doors, If you have a 2 door. You will need a rear driveshaft as well.
It can be upgraded to a long arm
Old Aug 27, 2012 | 11:26 AM
TeRC's Avatar
Cool thanks! Sounds like you can't go wrong with this.
