Built dana44 front vs prorock
So far, nobody has mentioned the ProRock 44 Unlimited housing, which will accept all the factory internals and factory Rubicon locker, as well as an ARB locker if you are building from scratch. This is a more affordable option for those that want a stronger option than the factory without buying a pre built axle assembly.
Not everyone needs a D60, and if you are honest with how you intend to use your rig, this is a great option.
The unlimited housing simply has castor correction nothing else is different then the standard pro rock 44 housing. You also have to either choose the ARB or the factory e locker. They are not interchangeable. When you get done swapping the parts over you still have an axle with weak unit bearing, factory brakes, and weak shafts. Upgrade that stuff and you are pushing 60 territory.
I do find it interesting when folks talk about the cost of a 60 vs an aftermarket 44, nothing ever gets mentioned about all the other things that have to be done for the 60.
When you add in the cost of arms, steering, wheels, driveshaft, etc., that "costs the same as a 60" price just is not the same.
Must compare all that is required to make each axle work in my opinion.
Have fun out there.
Have fun out there.
I think, for me, that's what makes that Fusion hybrid so interesting. At least for the front. The rear would still be a challenge to keep all the extra stuff stock if trying to go full float. It may not even be possible.
So far, nobody has mentioned the ProRock 44 Unlimited housing, which will accept all the factory internals and factory Rubicon locker, as well as an ARB locker if you are building from scratch. This is a more affordable option for those that want a stronger option than the factory without buying a pre built axle assembly. Not everyone needs a D60, and if you are honest with how you intend to use your rig, this is a great option.
Link didn't work on my phone. What about the balljoints? Still the same crappy joints?
Standard Options and Pricing:
- ARB 35 Spline D60 locker
- Yukon Gear R&P and Master Install Kit
- Gear Setup
- RCV 35 Spline Axle Shafts
- JK Brackets
- Heavy Duty JK Inner C's
Introductory Price: $5100 Plus Shipping
The only item not included in the price are Ball Joints. We can price those in depending on preference at a very good cost.
- Gear Setup
- JK Brackets
