Bully Dog Triple Dog GT Gas Tuner
Originally Posted by isshinryu28
Wish someone who had a SC and changed to this if one more power over other
Questions, while I (very anxiously) wait for mine. :-)
Do the mph and rpm match the Jeep's panel? Does the fuel consumption match the Jeep's computer estimate?
If so, how are the temperature gauges? Engine and transmission temperature? Since I have an auto I'll probably monitor the tranny's temp.
How do you like the driving coach? Is it really useful?
Another one. Is it possible to back up that micro-SDHC card so if it gets corrupted we just restore from the backup? I'm worried about losing the Jeep's factory setup.
How'd you do that? i didnt read the manuel too much either. i'd like to know
Still deciding
I am not being a smart ass but I am confused a bit. I was about to grab the SC before reading the other thread now I am leaning toward BD. As sweet as the real time monitor sounds why are people watching the gauges that the jeep already has? I am trying to talk myself into getting this but if the monitor is only stuff I can already see then SC sounds like it has slightly more power.
Has anyone switched from a SC to BD? If yes, was your performance basically the same with the BD tune?
Bulldog
I have mine set on coolant temp, trans temp, voltage and throttle position. I find my self using the throttle position to tell how hard I am getting on the throttle and increase my gas mileage.
I like having the Voltage so when I use the winch I can see the power drop.
Pat
Pat
OK that makes more sense
Pat
Pat
For what I read there are many gauges you can select to display. And each one as an analog display and/or a graph.
You can download BD's manual and check it out. I did it before ordering mine. ;-)
SC is promising something similar in May (Vivid), but it runs on an Archos Android device and it's way more expensive. Considering how some apps can literally screw some devices up I decided to go with a dedicated one.
I might reconsider in the future if they come up with a Windows app that I can run on my Viliv S5 UMPC. I can create a virtual machine there and isolate the tuner in its own environment.
Update?
I just read in another site that the dealers have a software update for 2010 wranglers that add power. Does anyone know if this is getting at the same power the BD is getting?
