bump steer
i have an 07 sahara 2 door. i put a 2.5" lift and 33's on it recently. i have been having issues with bump steer. i was reading about a little and i think what i need to do is get a track bar relocation bracket and drop the pitman arm. is that what i need to do?
honestly, i don't know how you could have "bump steer" with just a 2.5" lift but, installing a trackbar relocation bracket and dropped pitman arm WILL NOT help you here as they are made for lifts 4" or taller. now, if you feel like your steering is a bit flighty at highway speeds, you might want to check to make sure that you aren't running too much air in your tires and if anything, you may want to consider getting some adjustable lower control arms so that you can add a bit more positive caster.
http://rides.webshots.com/video/3016...02496289IjoMUo
