bump steer
Old Mar 8, 2014 | 11:11 AM
  #21
planman's Avatar
Forum Tech Advisor
Originally Posted by hollywd32
Ok a quick question- could the front lower arms be shortened a 1/2" and if so- do the upper arms have to be adjustwd accordingly also? Thanks
You would need to adjust the upper and lower arms, and then you'd need to redo the alignment caster specs.
Much easier to take a flap wheel to the edge of the bumper where there is a clearance problem and then paint over the bare metal.
Old Mar 8, 2014 | 12:03 PM
  #22
Jeepstin12's Avatar
Originally Posted by planman
You would need to adjust the upper and lower arms, and then you'd need to redo the alignment caster specs. Much easier to take a flap wheel to the edge of the bumper where there is a clearance problem and then paint over the bare metal.
Actually, fix that, but more importantly, reduce your drag link angle. That is the biggest culprit.
Old Mar 8, 2014 | 12:18 PM
  #23
Maertz's Avatar
what??????
Old Mar 8, 2014 | 12:33 PM
  #24
planman's Avatar
Forum Tech Advisor
His problem isn't bumpsteer. His front tires rub his front bumper on a full lock turn.
Old Mar 8, 2014 | 06:05 PM
  #25
Jeepstin12's Avatar
Originally Posted by Maertz
what??????
simple geometry. I should have clarified my first statement. Even with everything corrected on the geometry, drag link aside, it will still have bump steer with more of an angle on the drag link vs. reducing the angle as compared to the direction of travel. Sorry for the hurt.
Old Mar 8, 2014 | 06:40 PM
  #26
planman's Avatar
Forum Tech Advisor
He doesn't have bumpsteer. His tire tread was catching on his bumper on a full lock turn and he called it bumpsteer.
Old Mar 8, 2014 | 06:45 PM
  #27
Maertz's Avatar
what this guy ^^ said. I understand the geometry, was just confused why you tried confusing the op, or failed to fully read the thread.
Old Mar 8, 2014 | 07:00 PM
  #28
Jeepstin12's Avatar
I don't typically go back to the op. I saw the most recent. No intention of confusing anybody.
