Bump steer with tf bb
Not enough lift for a dropped arm. If your steering is a little flighty and you have bump steer then I would get some lowers and dial in your caster. It will tighten up your steering and hopefully eliminate your issue. Also, make sure everything is torqued properly in the front especially your track bar.
Depends on your current setup and angles. I believe Drop Pitmans work in conjunction with a Trackbar Relo bracket. If you use one without the other, your steering angles are off.
Watch this vid by teraflex, take a pic and connect the dots to see where you are now.
http://rides.webshots.com/video/3016...02496289IjoMUo
Also, if you decide that you need one, do a little more research first. The general consensus seems to be that drop pitmans put excessive force on the steering box/components, and flip kits are preferred.
No, it will make your handling worse and mess up your steering geometry. Drop pitmans are a bad idea anyways, they add extra stress to your sector shafter in your steering box. With that small of a lift, you more likely feeling small bumps in the road and not true bump steer.
