Bump stop or not?
Old Jul 31, 2009 | 09:58 AM
toyfreak's Avatar
Default Bump stop or not?
I installed the bump stops when i put my 2.5 TF lift on.
Did I need to do that? SHould i take them out? What do I need to Watch for if i take them out?
Old Jul 31, 2009 | 10:57 AM
porters's Avatar
The answer is that it depends. If you are running longer shocks bump stops prevent the shock from being damaged by compressing them beyond their design. Also, bump stops prevent larger tires from compressing as far and rubbing on the fenders.
Old Jul 31, 2009 | 02:28 PM
lv jk's Avatar
***erator
What you should do is take out the springs and fully cycle your suspension. see if the bump stops are keeping the shocks from bottoming out or if the tires rub.
Old Jul 31, 2009 | 05:48 PM
nthinuf's Avatar
