Bump stop question
Old May 1, 2013 | 10:10 PM
SWRUBI's Avatar
Default Bump stop question
I see that there are 'upper' and 'lower' front bump stops available for our JK's. What is the benefit of each and why would you use one versus the other?
Old May 1, 2013 | 10:15 PM
Sparkplug's Avatar
I can't think of benefit if you are only using one or the other.
Old May 1, 2013 | 11:41 PM
nthinuf's Avatar
You use one over the other because that is what came in the kit you bought? Front lowers need to be drilled/tapped, so I guess that would be the negative between the two. Though the uppers can be a pain to get seated up in the cup with the coil in.
I prefer upgrading the lowers. Just a personal opinion, with no real objection to uppers.
Old May 2, 2013 | 12:22 AM
gunbo75's Avatar
Yep x3 on that. use what comes in your kit.
