Bump stops
Old Dec 9, 2010 | 07:03 PM
knight1000's Avatar
Default Bump stops
Can someone explain bump stops to me. I dont understand why after lifting 2-3" bump stops have to be used. Isnt the point to get more travel not just height?
Old Dec 9, 2010 | 07:13 PM
Robar's Avatar
The bump stops limit the up travel preventing over compression of the springs and rubbing.
Old Dec 9, 2010 | 07:28 PM
wayoflife's Avatar
JK-Forum Founder
as mentioned, you want bump stop extensions as they will help prevent the over compression of your coils. a lot of people also use them to help prevent rubbing at a full stuff.
Old Dec 9, 2010 | 07:40 PM
nthinuf's Avatar
More down-travel is good. Up-travel, as noted, puts the tires through the fenders and can cause over-compression of the coils. Some coils are designed to survive over-compression, some aren't, just depends on the coils and the mfg.
- (I was in contact with a tech supervisor for OME concerning this, who referred me to a senior design engineer down in aussie-land. He quoted some 'solid stress MPa' numbers, and said that OME coils will not be harmed by over-compression, but suggested adding bumpstops anyway.)
