Bumper light upgrade question
Old Aug 9, 2009 | 06:31 AM
Riptyd's Avatar
Default Bumper light upgrade question
Hey all-
I just installed a smittybilt SRC front bumper. I am going to be installing KC Daylighter 100W lights. I would like to use the foglight wiring harness from the stock bumper. Can I do this without jacking up the CANBUS or creating other problems. How should I wire it? pictures would be great. wiring "Schematics are useless" I aint to bright. thats why I got bigger lights. just a simple description will be fine.
Old Aug 9, 2009 | 09:25 AM
JKWillie's Avatar
What you wanna do will work fine.
Again , I have the same bumper & I used the factory wiring harness for my new lights as well. The factory plugs on the ends of the wires will not work, but you can just cut those off & still use the wiring itself.
Just connect the factory wiring to your lights.....AND.....there ya have it!
Old Aug 9, 2009 | 03:17 PM
08jk4door's Avatar
when you use the factory switch does that mean you can not run high beam and fogs at same time also you have to have the car on right ? just asking i do not have factory lights
Old Aug 9, 2009 | 03:46 PM
kd5zwf's Avatar
I did the same not too long ago. Just get some blue splice connectors and presto there you have it. Once you go High beams they shut off though. I have some windshield lights that work only with highbeams.
Old Aug 9, 2009 | 03:47 PM
GoodysGotaCuda's Avatar
Solder is your friend, blah to butt connectors!! Nothing but voltage drops waitin to happen
Old Aug 9, 2009 | 07:46 PM
JKWillie's Avatar
It just depends on how you wire it and yes, you should have the Jeep running so the lights don't run down the battery.
Old Aug 10, 2009 | 05:44 PM
Riptyd's Avatar
bump
