Bumper with vacum pump mount?
Old Nov 24, 2014 | 03:39 AM
bthomas's Avatar
Ace stubby pro only requires remounting the pump on the same bracket, just moves above or below the bracket, can't remember for sure.
I just installed a poison spyder brawler lite on my 12 and it didn't require moving it at all.
Old Nov 24, 2014 | 05:59 AM
JE8154's Avatar
Originally Posted by espi
You can always just drop the pump under the bracket. It costs about $5 in parts and no rewiring. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=585355"/>
Assuming that will still fit with the bumper on. Anything where you're cutting frame will need it moved out of there.
Old Nov 24, 2014 | 06:39 AM
Dodge4me's Avatar
Smittybilt XRC Mod bumper accommodates not moving it.
Old Nov 24, 2014 | 07:10 AM
espi's Avatar
Very true, although if he is worried about moving the pump I doubt he is looking to cut the frame. Where I mounted it is pretty easy here is what I did.
Parts cost $5-$7
I cut off the studs and used a cut off wheel to cut the bottom part of the front stud off so I could put a bolt through the top.
I pulled connector off the mount and used the front hole that the Christmas tree holder went in for the other bolt.
The bolts I used were 1/4-20 x 2 1/2" I put them through the two holes above then put 7/8 threaded spacers on.
I flipped the rubber shock mounts and put a washer on before mounting the pump. I secured everything with a nyloc nut.
With this setup the pump is just under the mount and drops between the crashbar. There is no need to rewire or plumb.
One issue I did have though was the bolt I used was hitting my Zeon winch which is much wider then most. So I just bent the mount down a little bit.
Old Nov 24, 2014 | 07:35 AM
JE8154's Avatar
Very true, although if he is worried about moving the pump I doubt he is looking to cut the frame. Where I mounted it is pretty easy here is what I did. Parts cost $5-$7 I cut off the studs and used a cut off wheel to cut the bottom part of the front stud off so I could put a bolt through the top. I pulled connector off the mount and used the front hole that the Christmas tree holder went in for the other bolt. The bolts I used were 1/4-20 x 2 1/2" I put them through the two holes above then put 7/8 threaded spacers on. I flipped the rubber shock mounts and put a washer on before mounting the pump. I secured everything with a nyloc nut. With this setup the pump is just under the mount and drops between the crashbar. There is no need to rewire or plumb. One issue I did have though was the bolt I used was hitting my Zeon winch which is much wider then most. So I just bent the mount down a little bit.
If he can't take out and put in 4 bolts for say the evo pump relocation then he should find a friend to help him with the whole process and pick out whatever bumper he wants. Picking a bumper based on moving the pump almost guarantees he will end up buying another bumper in a year or two.
