Bumper weight vs perfomance
Old Nov 13, 2014 | 04:28 PM
htm7765's Avatar
Default Bumper weight vs perfomance
In all the reading I have done I read that bigger tires and addition of bumpers really hurt MPG and performance, I did the tires 33 not crazy. I do notice a performance issue more so highway pulling hills, the jeep doesn't pull as well with the stock wheels and tires MPG has not dropped to bad averaging 18.8 / 19.3 on 87 octane.. So I really want to upgrade the bumpers and install a winch over the winter but if it drops MPG and hurts performance I might scrap the idea.. Not sure of what bumpers I want yet still looking but if I have to sacrifice more power I won't do it any insight is appreciated
Old Nov 13, 2014 | 04:43 PM
Moezer's Avatar
What jeep u have and gear ratio
Old Nov 13, 2014 | 04:49 PM
afpilot82's Avatar
JK-Forum Ambassador
If you're that concerned about weight, there are several companies out there making aluminum bumpers.
Old Nov 13, 2014 | 05:00 PM
htm7765's Avatar
2011 manual Trans 373
Old Nov 13, 2014 | 09:14 PM
Moezer's Avatar
U can always get a supechip flaspaq to gain somepower bck
Old Nov 13, 2014 | 10:17 PM
TJM12's Avatar
Regear to at least 4:56 or preferably 4:88 and you'll be really pleased with the performance even with heavy bumpers and winch.
Old Nov 13, 2014 | 10:35 PM
spicoli's Avatar
It's a jeep. Not the most gas efficient and not the lightest vehicle. Tires and lift will make a noticeable difference to your mpg, but bumpers and winch won't.
Driving style will make the biggest difference to your mpg. Watch the lead foot and don't drive too fast and you will get a lot better mpg. One of the reasons we used to have the old 55mph limit was to help conserve gas.
Old Nov 14, 2014 | 01:20 AM
GJeep's Avatar
To the OP:
More weight means that more energy is needed for moving it. More energy is increased fuel consumption.
The same goes for braking. Braking more weight is increased brakes wear.
If you don't really need a winch, don't get one... and if you do install a winch, you can use synthetic rope, which is much lighter than steel (and much less dangerous).
Re-gearing would improve power, but not necessarily improve mpg.
Very true.
From about 60 mph and higher, the 'cube aerodynamics' of the Jeep makes air resistance a very meaningful factor regarding mpg.
Old Nov 14, 2014 | 04:16 AM
htm7765's Avatar
That's everyone, I understand the Jeep is not a fuel efficient vehicle nor loaded with power, it serves a duel purpose for me a toy and a DD, I travel about 50 mikes per day with that 35 is highway, I have seen the variance in MPG depending on my driving I do around 65 the speed limit and I do ok 5 miles faster I see a big drop, so to improve my fun time and not always having a fellow off-roader with me I feel better if I had a winch incase I got in trouble, so I am trying to make a reliable off road vehicle that's a DD I do not want to change gears i was really trying to get some feed back on the impact of adding weight,,, one reply to this thread mentioned aluminum bumpers any leads on who
Thanks again
Old Nov 14, 2014 | 06:13 AM
scubatech's Avatar
Thanks again
I installed a 3" lift on my wife's 2012 Ruby, 3.73 gears and 33" tires. I also added a winch and front & rear steel bumpers. She didn't lose more than a mile per gallon. That's calculating fuel used & fuel added to the tank, not the computer in the Jeep. Those are good investments if you off road versus a minor loss of mileage.
