Bumpstop options?
Old Sep 8, 2009 | 10:21 AM
jwetzel's Avatar
Default Bumpstop options?
So I put a Teraflex 2.5 BB on my rubi, and the extended front bumpstops are too long. I think they're intended more for keeping 35's from rubbing the fenders, but I'm running 33-12.5's, and it hit the bumpstops with about 2.5 inches of clearance still up in the fenders. Seriously limiting my flex.
So I tried cutting some rubber off the stock bumpstops (the part that sits inside Teraflex's extensions) and that gained me about an inch of uptravel, but I still need maybe 1.5" more.
Are there any other options? Does anyone make a one-piece bumpstop like the stock ones, but just an inch longer? I can't find anything on any of the vendors' sites.
Old Sep 8, 2009 | 10:27 AM
RN M OVR's Avatar
Be careful how much you cut because you are using a budget boost, not longer coils. The bumpstops are designed to keep your coils from sliding off the BB or the BB from falling out due to too much flex.
I have a 2" budget boost with longer bumpstops. I know it may seem like your flex isn't alot but I bet you you are getting a good amount for the type of wheeling a BB should be receiving.
My advice is don't cut your bumpstops anymore and understand their purpose with a BB, or get longer coils with perhaps spring retainers if you want more flex.
Old Sep 9, 2009 | 04:04 PM
Robert's Avatar
Default Use the stock bumpstops?
Have you tries using the stock bumpstops instead? You could put them on and recheck your flex and clearance. It may be a dumb idea, but it sounds reasonable to me. My 2.5" lift didn't even come with new bumpstops.
Old Sep 9, 2009 | 04:51 PM
nthinuf's Avatar
Read the notes on your 2.2 shocks...
Old Sep 10, 2009 | 01:51 AM
Robert's Avatar
I'm not sure they count the same as the behemoths on some kits, but yes they do have a little bumpstop on the shock.
