Bye Rear DS and other problems
Old Nov 28, 2010 | 08:14 AM
Dozilla's Avatar
Default Bye Rear DS and other problems
After looking over the Jeep this morning post wheeling trip I noticed I finally got the rear drive shaft weeps. Thank goodness my new one will be here any day now from Northridge4x4. Also I noticed my trac bar is loose at the end that is adjustable. I guess I will be ordering one of them now. Finally, which is my biggest concern, I noticed some seapage at the pitman arm. Is this something I should be concerned about.
Rear drive shaft:
Pitman Arm:
Trac Bar:
http://www.youtube.com/watch?v=ucc4DBQoGBA
Old Nov 28, 2010 | 08:47 AM
mkjeep's Avatar
DS definately toast, pitman doesn't look too bad as long as it's not dripping. What tracbar is that? Kinda looks like a hack weld job on a jamnut to keep it from loosening
Old Nov 28, 2010 | 09:30 AM
Dozilla's Avatar
It is Rusty's. There has been many problems with this company as I am slowly finding out. This was there 2nd generation tracbar cause there first was even crappier than this one.
Old Nov 28, 2010 | 09:43 AM
mkjeep's Avatar
What keps that collar from loosening?? IMO take that pos off, get something better. I have a TF moster front and rear, they're stout as hell and easy to adjust.
Old Nov 28, 2010 | 09:46 AM
Dozilla's Avatar
Its coming off as soon as I get a little cash to buy a new one. how long you think that RDS will last before anything major occurs. Is it ok to run back and forth to work for a little bit. 25 miles round trip.
Old Nov 28, 2010 | 10:07 AM
mkjeep's Avatar
Pics of the TF bar before I got the drag/flip kit. The only thing it would hit some on the RC dual center mount that bolts to the axle off-road. Everything else cleared fine. With a single stab, no issues whatsoever.
Name:	Snow Concert Tinkerbell 057.jpg
ID:	105408Click image for larger version
Name:	Snow Concert Tinkerbell 050.jpg
ID:	105409Click image for larger version
Name:	Snow Concert Tinkerbell 052.jpg
ID:	105410Click image for larger version
Name:	Snow Concert Tinkerbell 055.jpg
The comparison pic was against the Superlift trackbar, The monster weighs twice as much as it.
Old Nov 28, 2010 | 10:13 AM
mkjeep's Avatar
If it's loose were those threads are, I'd have someone weld it where the threads are and make a temp solid track bar till you can get another one.
You absolutely DO NOT want it coming apart at highway speeds especially. Have a welder look at it, show him where the movement is and have him bead it up. Prolly charge you $20-$40
Old Nov 28, 2010 | 10:21 AM
Msrunner's Avatar
How much use did you get out of that drive shaft before it began to leak?
Old Nov 28, 2010 | 10:31 AM
mkjeep's Avatar
Think he put the lift on in July 09, so he's had it on about a year and 4mo's.
Old Nov 28, 2010 | 10:50 AM
Dozilla's Avatar
Damn MKJEEP, you are right on. Have you been stalking my Jeep.
