C Gusset weld on cost?
Old Sep 20, 2012 | 09:43 AM
Firelyle's Avatar
Originally Posted by Serg5000
Welding in 1 inch strips and wait till it is cool to the touch. I welded one strip on top and one strip on the bottom then moved to the other side. So far so good.
Did the same thing. Also used wet rags to cool off the metal as well, as those axles hold heat for a long time.
Old Sep 20, 2012 | 02:01 PM
blue project's Avatar
Just had mine done the other day. Labor was 135 and a total of 225 for everything. I had a local Jeep shop order mine from off road evolution.
Old Sep 20, 2012 | 02:21 PM
mook8651's Avatar
I've done a few axels C's an trusses an I used cold rags after I weld a inch or so am just jump around to distribute the heat but I'd do all the work myself for mine but ive done a few for 100$ an that's me doing all the work an bs'sing with ya the whole time.. All you have to do is drink beer an watch me work which isn't to bad lol
Old Sep 20, 2012 | 02:50 PM
Mic4x4's Avatar
Here in NM the shop prices are either ridiculously outrageous or you have to wonder if they can even do it... Got mine done at one of the larger well known shops, Was quoted $150 for uppers only parts and labor. When I went to pick up I ended up paying about $250. Needless to say it was the last time I went to any shop I'd rather spend the money on tools.
Old Sep 20, 2012 | 03:00 PM
nmwranglerx's Avatar
Yea I hear you, I called 4x4 shops around ABQ, NM where I live and they wanted to pull ball joints instead of soak them. They quoted me something ridiculous like $500. I looked on CL and found a mobile certified welder with 25 years of experience. He came to my place and only cost me $100 and some beer afterwards. He took his time and we soaked ball joints with wet rags every few minutes to keep things cool.
Old Sep 20, 2012 | 06:45 PM
knightrohulk's Avatar
Wow, that's a good idea. Didn't know that was possible. Thanks for sharing.
Old Sep 20, 2012 | 09:06 PM
Dawdge's Avatar
I'm here in alb nm too! Looking for some shop to do my c gussets as well.. Where did you find that guy at?? Im looking around, desert rat said they could do it but didn't quote me. Is this guy legitimate? Cause desert rat warranties their work.........
Old Sep 20, 2012 | 09:18 PM
TheTerminator's Avatar
I got the C's together with LCA skids F/R done for $150. I was charged for 1.5 hours of labour. However, I did have a quote for $800 (8 hour labour) to do this job, which is...
It pays to shop around. Don't just walk in into the 1st shop you see. A lot of them will just take you for a ride, if you do.
Old Sep 21, 2012 | 08:07 AM
Rooster454's Avatar
I had the evo upper and lowers welded on for $110 and that included pressing in and out the ball joints to make sure they didn't get too hot.
I got quotes from $290-500 and then a friend recommended this 4x4 shop I had never heard of as it was an hour away from me and they did a damn good job
Old Oct 30, 2012 | 06:18 AM
keahyukchang's Avatar
Default I do have 35" tire(2.5" lift) about a 3 weeks ago, shall i get this done?
Hello experienced, I need advice.
I have 2010MY JKU AT(3.73 axle), and each tire and wheel weighs 87 lb.
Do I need to get this done?
If I need to get this done, do I need this for front and rear?
Seems cheap welders are around $100~200 range, similar to cost of getting it done.
Shall I learn to use it and DIY?
(Being capable of welding seems to be a plus for Jeeper)
