C-gussets hit speed sensor wire retainer
Old May 16, 2016 | 07:49 PM
Slowpony46's Avatar
Default C-gussets hit speed sensor wire retainer
I'm getting ready to install Evo c-gussets on my Dana 30. Axle is sitting on stands. I put the upper gussets in place to see how they fit and found that with it in place the bracket for the speed sensor wire hits the gusset and limits the knuckle from turning all the way. I think I can bend the bracket out of the way but in all the pics I can find they look unmodified so I'm wondering if I did something wrong. Anyone else put these gussets on and find this issue?
Old May 16, 2016 | 07:58 PM
Albino Lizard's Avatar
Its been a while since I installed mine, but I believe I had to make some adjustments for those brackets. A little bend and they were fine.
Old May 16, 2016 | 09:00 PM
Christian13's Avatar
Yep all you gotta do is one full turn from lock to lock and those tabs will move out da way
