Cable or rope winch?
You'll easily realize the steel cable winches are less expensive simply because of the cable. Yes, synthetic rope is pricier but for good reasons.
-It is much safer as it doesn't store any energy as tension is placed on it, if it breaks, it will fall to the ground unlike a steel cable that will turn into a whip until it hits something.
-Synthetic rope also floats in water.
-It's just easier to handle and won't kink like wire rope will.
-Synthetic comes in some cool colors.
-Synthetic rope can be repaired if it does break, the end still connected to the winch can simply be weaved back into itself to create a new loop (do NOT put the two pieces back together!). I have done this with no further breaks.
-Lastly, it's much lighter than steel cable.
That should answer your questions...
You'll easily realize the steel cable winches are less expensive simply because of the cable. Yes, synthetic rope is pricier but for good reasons. -It is much safer as it doesn't store any energy as tension is placed on it, if it breaks, it will fall to the ground unlike a steel cable that will turn into a whip until it hits something. -Synthetic rope also floats in water. -It's just easier to handle and won't kink like wire rope will. -Synthetic comes in some cool colors. -Synthetic rope can be repaired if it does break, the end still connected to the winch can simply be weaved back into itself to create a new loop (do NOT put the two pieces back together!). I have done this with no further breaks. -Lastly, it's much lighter than steel cable. That should answer your questions...
Syn is UV sensitive and can be internally damaged if you use it in mud or contaminated water often. It comes down to what kind of maintenance and use you're willing to do.
Search though, this has been debated only a million times.
Cons are;
Synthetic rope can cost as much as the winch you're putting it on.
Has about a 5 year lifespan with regular use.
UV exposure damages it very quickly. Needs to remain covered when not in use.
It frays fast if you use it a lot. Chafe guards help.
Needs to be hand washed to remove grit from mud and sand.
Requires a special fairlead.
Prone to buying itself deep into the spool under heavy load. Can be difficult to unspool afterward.
I still use synthetic line on my winch. I'm also on my 3rd rope in less 8 years so it comes at a price.
Cons are;
Oh lastly Synthetic is a fraction of the weight of steel, way nicer to work with.
Dave
