CAI install HELP....
Old Mar 3, 2009 | 04:33 PM
alleycat's Avatar
Default CAI install HELP....
I installed my Airaid today and after that my check engine light came on. After about an hour of driving it went off. What could I have done wrong to make it come on?
Old Mar 3, 2009 | 05:05 PM
JPop's Avatar
It's simply the AIT and the O2 Sensor reporting what the ECM thinks are erroneous readings. Your engine was probably leaned out with more air getting through than what a simple intake temperature sensor could validate as it doesn't read volume. I'm sure the ECM will get it worked out, but I wouldn't be surprised if you run a little on the lean side.
Old Mar 3, 2009 | 08:27 PM
mkjeep's Avatar
Disconnect your battery for 10min. Mine did that, no more check engine light.
Old Mar 3, 2009 | 08:28 PM
mkjeep's Avatar
Cancel that, you said it went off, sorry, if it was still on do the battery thing.
Old Mar 3, 2009 | 08:35 PM
x No Compromise Offroad x's Avatar
it's just an air flow sensor most likely
Old Mar 4, 2009 | 02:20 AM
RedneckJeep's Avatar
You probably cracked the flux capacitor. Happens all the time.
Old Mar 4, 2009 | 09:38 AM
....hate it when that happens....better call Doc Brown
Old Mar 4, 2009 | 10:57 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Nothing a little duct tape cant fix I have one I fixed with some that I maybe willing to sell
here is some cai driving help, watch out for the big puddles
